I have a 1990 XJ6 Vanden Plas (XJ40) whose ‘‘Charding’’ light
came on while driving. (Fourth Symbol on the left hand
error display).
I, of course, did some immediate tests on the battery and
from those readings determined that it was the alternator
(115 Amp). The AMP guy was surprised and said the alt
looked fine, but regardless, took it apart, turned it,
replaced the brushes, and bearings and poof, I put it back
into the car (I have a write-up on that I will soon rmit to
the list).
Upon placing back in–poof! Same light on the dash.
Secondary troubleshooting found a FUSE 1 failure when I turn
the ignition key on, then press VCM. It Flashes: Fuse 1,
then PRO, then FAIL. Not sure what that means.
I surmise that either FUSE 1 (where is it? And is there a
listing of all the fuses on the car here?) is bad or
something in its related circuitry.
As I am dog-fighting a ‘‘Transmission Light’’ failure
also–I’m not a happy camper.
Questions:
1.) Where is FUSE 1?
2.) What does the VCM flashing code mean? Fuse 1, then
PRO, then FAIL?
3.) Is there a print out of all the VCM codes somewhere?
4.) Is there a place I can read to truly operate the VCM to
its highest potential?
5.) And finally, why is the sky blue?
Any responses will be greatly appreciated.
RLCII–
RLCII
