In reply to a message from ChinaTom sent Sat 6 Jan 2007:
May I add some additional information to the excellent reply from
Bryan? The following information on the connections on the LB36
Pin #10 is the ignition power to the radio.
Pin #11 is battery power direct to the radio and is used to
activate the antenna logic on pin #4.
Pin #12 is instrument illumination feed coming from the fascia
centre console.
Hope this helps.
Trennie–
In reply to a message from ChinaTom sent Tue 2 Jan 2007:
I have fitted a replacement radio, and this has half solved the
problem. I now have power to it, and I input the code and the radio
trennie
