I’ve succeeded in replacing the fuel pump, however, the car
won’t run above idle w/ the Temperature Coolant Sensor
connected. Starts and drives w/slight handicap
disconnected.I’ve cleaned all associated connections,
including the MAF connector. Throttle Position Sensor will
not give the full range, only .57-5 volts, instead of .57
-6.2v. I’m getting about a 40% power loss upon accelleration
and full throttle. It slowly bogs a second and then
accellerates. I’m beginning to suspect a bad ECU. But, I
would rather rule out all other possible faults, first. I’ve
cleaned the ECU connetions, too.
Any suggestions??–
droland
FL, United States
