First off: you only get failure codes when pressing the VCM button in
position II (engine starter not engaged or engine not running)
Secondly the 02 Sensor report is most likely a result of being fouled
from the main cause so not something to be concerned about.
The EGR would seem to be in the same ball park as the EGR though that
code usually relates to the solenoid valve (at the LH rear of the engine
from the driver seat) there is a blue bottomed solenoid vale with vacuum
hoses that run to the EGR and electrical connections. If the EGR
solenoid is hanging it could be the cause but its more likely the the
throttle put needs cleaning and or adjustment and perhaps cleaning of
the electrical connections with electronic contact cleaner and coating
with dielectric grease. If the vacuum hose was off you would not be
intermittent.
When was the last time you cleaned the idle orifice valve and the TPS or
the inlet air temp sensor and throttle body?
They all get gunked from the condensed oil fumes from the crankcase and
valve cover.
I’d hazard a guess your TPS is hanging up or malfunctioning some of the
time and causing the engine to go to limp home mode and/or your inlet
air sensor is gunked up. This problem generates the others. I’d start
there.
Its always a good idea to pull the plugs and give them a read for color,
soot, oil etc. on each cylinder to determine if you have an injector
sticking bad plug, bad valve etc. but my guess is you first need to fix
the TPS problem, make sure its clean and set properly.
Jay 90 VDP Majestic
Enfield303 wrote:
My engine’s performance has varied over the past couple
weeks. Sometimes, it’s ran very smoothly without the
slightest skip. At one point it was skipping terribly and
running very rich accompanied by black soot on the tail
pipes. So far, I’ve only got Fuel Fail codes when the car
wasn’t running with the key turned so that the fuel pump
hums and all the warning lights come on. At first it was
Fuel Fail 17, referring to the throttle position sensor.
Later I got Fuel Fail 44, referring the oxygen sensor, I
believe. Then Fuel Fail 37, something to do with the EGR
system. And now, it’s running back to running good again
but skipping a bit when it’s first cranked and is back to
Fuel Fail 17. …?
I’ve been wanting to give my car a tune-up. I guess I’ll
start with the plugs and wires but all these codes coming up
have me confused as to what else I need to look into.
Richard - 1992 Sovereign (4.0L)
Fountain Inn, South Carolina, United States
