My March 7, 2013 post detailing my installation of a fuel
line check valve prompted several off-line conversations
regarding valve placement. The most common opinion was that
placing the valve at the fuel rail was not only acceptable,
but preferable to placing it close to the fuel pump/tank,
because �All that matters is the pressure in the fuel rail.�
For convenience, I first installed my after-market valve in
the flexible hose at the rail, but fellow member
aerostarflyr told me that a check valve vendor informed him
that the valve should be installed as close as possible to
the fuel pump/tank. Since I happened to have the IRS out of
our car for a differential overhaul, I moved the valve to
the flexible line beneath the tank on our �93, which has the
in-tank pump/housing/check valve assembly.
When members began emailing me to say that the valve would
work just as well at the fuel rail, the only response I
could muster was, �So why do so most auto makers place the
check valve just ahead of the fuel pump?� Only one member
had an answer: �It�s less expensive for the manufacture to
install a single pump/check valve assembly than separate
components,� which may be true, but doesn�t explain why, on
earlier XJ40s, the check valve is a separate part from the
pump, yet is not mounted at the fuel rail but rather
connects directly to the outlet of the pump.
My extensive online searches have found no authoritative
explanation. However, in pondering this dilemma, I believe
I may have deduced the answer. For your consideration, I
offer my theories of operation of the two configurations,
assuming all other parts/systems are working properly (FPR,
coolant temp sensor, carbon canister control valve, ignition
system, battery and starter circuit, ECU, etc.), and all
cylinders have good compression.
Scenario 1, Check Valve at the Fuel Rail: While the engine
is off, fuel line pressure dissipates back through the pump
from the check valve to the tank. When the engine is
cranked and pressure in the rail drops as the injectors
operate, the pump must re-pressurize the entire fuel line
from tank to check valve/fuel rail before pressure at the
rail is restored. Since the pump�s rate of flow is
insufficient to re-pressurize the entire fuel line
instantaneously, it seems logical that there will be a lapse
of pressure as the engine tries to start, contributing to
extended cranking times.
Scenario 2, Check Valve at the Fuel Pump: While the engine
is off, pressure is maintained between the check valve and
fuel rail, which is to say, in nearly the entire fuel feed
line. When the engine is cranked, the pump needs only to
re-pressurize/prime the short distance between the pump
outlet and check valve before it is already restoring fuel
rail pressure lost through the injectors. Theoretically,
this should minimize any pressure lapse at the fuel rail and
shorten cranking times.
That�s my hypothesis. I welcome all thoughts of assent or
dissent!
Cheers,
Don–
Don B : '93 VDP Flamenco Red 189K : (ex-'88 Sovereign)
Franklin, TN, United States
