Hi,i’ve got a 1987 XJ40,wich I use for rallycros.Last race
yesterday,the gearbox failed.It is working only in reverse gear,all
forward gears are gone.The box is a ZF automatic.Since I am not
familiar with automatic gearboxes,can someone help me out on this
one?
Thanks,kris–
Blitz!
In reply to a message from Blitz! sent Mon 2 Jul 2007:
If the oil level is okay, check the filter to see if it is dirty.
From here you need skills…Check to see if the main pressure
control vavle is seized, after this you could have a bad A clutch
or slipping oneway clutch on D clutch. The last two are rebuilds of
the tranny.–
Sorry to hear about yr trouble. Any chance of seeing some
rallycross XJ40 pics of your car ?
Thanks
p.s. Am abroad after for 2 months, so forgive me if I’m not
able to say thanks if you do post them !–
Take off the trans oil pan (after draining and saving the fluid) and the filter is right there.
You need to measure the amount of fluid you drain in order to refill the trans to the same level, you don’t want to put too much back in after cleaning or replacing the filter.
