I bought my 89 in 2004 and the a/c worked fine for three
years, and then I had to replace the blower motors and they
worked fine for a long time. Last year I started getting a
problem with the a/c when turned on would blow the fuse on
the passenger side, which it says is connected to a/c
clutch…it was intermittent and was more likely to blow on
hot days…so, we assumed it was the compressor, and I went
through replacing with a new compressor, new switch, new
dryer, and whaever else was needed - expansion valve I
believe. This was all new parts that came recommended. So, I
had the work done in Las Vegas while I was temporarily moved
there, and the shop installed all the new parts and the
circuit failure stopped, and the fuse stopped blowing, and
the a/c worked…then about three months later, all of
sudden - no cold air one day, just out of the blue. So,
eventually after going through the winter in Cali and not
really needing the a/c and knowing the parts were under
warranty for a year, I got the money together and had a shop
in Pasadena,CA look it over and determined faulty parts-bad
a/c switch,etc…so, after $300 more dollars of labor the
replaced under warranty parts were installed and I had cold
air again…then about a month ago, guess what…one day, the
circuit failure starts up again…and it just seems like
under hot conditions this car’s a/c cant hold up…but its
weird because I went through three hot texas summers and the
a/c worked fine…my trusted Jag mechanic for many years in
Pasadena,CA wont work on a/c…has anybody seen or had this
problem and figured out what exactly is happening when you
get the circuit failure coming on and the blown fuse when
you switch on the a/c? Please educate me, I’ve now gone in a
complete circle in a year and a half dealing with this and
its hotter than hell right now in LA! THANKS TRUSTED FORUM
(MECHANICS HATE IT WHEN YOU TELL THEM YOU READ OR
COMMUNICATED ON A FORUM LIKE THIS, BUT I ALWAYS TELL THEM
THAT JAGLOVERS KNOWS A LOT!)–
DavidPlank89VandenPlas
Los Angeles, Ca, United States
