I have a knocking noise from the engine area even while the car is
idling and not in motion. It happens about twice per second on idle
and speeds up a little when the accelerator is depressed. I seem to
be able to feel this if I keep my foot on the brake pedal whilst
stopped. Any ideas on this one please.–
bassbandit
St Austell / Cornwall, United Kingdom
In reply to a message from bassbandit sent Sat 1 May 2004:
What year / model of car?
Be more specific - the engine area is pretty large! Can you isolate
it to a more precise area - even using a mechanics stethoscope (or
a long screwdriver pressed to your ear and t’other end placed on
the suspect area)–
Bryan N ('91 Sovereign 4.0 L)
Cambridge, United Kingdom
As Bryan, our beloved Godfather of all things XJ40, sagely stated … “Be more specific - the engine area is pretty large!”.
Please take Bryan’s advice and use a mechanics stethoscope to track down the noise. If you own an XJ40 and you don’t own a $10 (for a really good one) stethoscope you are relieving yourself into a brisk breeze.
Unless I’m mistaken the ‘helicopter’ noise is due to.a faulty damper in the fuel feed hose ahead of the fuel pressure regulator, not the non-return valve.
