In reply to a message from Henge sent Wed 15 Oct 2014:
As promised - see below:-
FAN (BLOWERS) CONTROL
OFF - The system is not operational. Power is off, but a
signal is sent to the climate control ECU to ensure that the
re-circulation (blower intake) flaps are closed to prevent
outside air from entering the car.
LOW � In automatic mode, the climate control ECU maintains
blower speed within a range of low speeds, depending on the
temperature requirement, fan speed being gradually reduced
as the target temperature is achieved
MED � In automatic mode, the climate control ECU controls
the full range of blower speeds, depending on the
as the target temperature is achieved .
HIGH - The blowers run at high speed only.
DEF - The blowers run at high speed - full air flow at �full
heat� is directed to the windshield.
[NOTE: When heat is required, the blowers will not operate
(unless the fan speed is set to �DEFROST�) if the engine
coolant temperature is below 85� F]
TEMPERATURE CONTROL
MANUAL button NOT selected � The climate control ECU
maintains selected IN-CAR temperature within a range of 63�
to 86�F
MANUAL button IS selected) - VENT outlet temperature is
maintained at the level selected by the driver.
[NOTE the differentiation between �In-car temperature� and
�Vent outlet temperature�]
MANUAL BUTTON
Not selected - AUTO - The system is under ECU control and
automatically maintains the selected IN-CAR temperature.
Selected - MANUAL - The system sensors are overridden and
the selected temperature is provided at the VENT outlets.
DEMIST BUTTON
When selected / illuminated - Windshield demisting is
provided but with NO change to air temperature.
AIR CONDITIONING BUTTONS
MAX � Provides maximum cooling, overriding all other
functions except �DEFROST� and �OFF�. It is a manual setting
which automatically sets the system to the highest available
fan speed and gives the coldest air from the vents at the
maximum de-humidifying setting
ON � when selected cancels the MAX button and provides air
conditioning at the minimum de-humidifying setting.
FACE VENTS SLIDER CONTROL
The outlet air temperature of the two SIDE fascia vents can
be controlled by the sliding bar (but only as a reduction
to its temperature in relation to the temperature of the air
at the foot well vents). Full up decreases side vent air
temperature; full down increases side vent air temperature
up to the temperature of the air from the foot well vents.
RECIRCULATION BUTTON
When selected, shuts off the outside air intakes at the blowers
HEATED FRONT SCREEN BUTTON [Where fitted]
Operates front screen heater for up to six minutes when
selected manually and is automatically switched on when
�DEFROST� is selected on the fan speed control.
I will send you further information on systematically
checking the operation of the HVAC system in another post–
I have owned the wonderful 1994 xj40 for 10 months, I don’t
have a owners manual, but I know the heater worked better
Bryan N, now Jag-less, but fun while it lasted.
Cambridgeshire, United Kingdom
