In reply to a message from Win Dooley sent Tue 23 Dec 2003:
I just finished this job on my '92 Sovereign with 151,437 miles. I
did it from above, removing the intake elbow and oil filter, and
squeezing my arms in around the throttle body. Screwdriver and
13mm box-end wrench, plus a strap wrench for removing the oil
filter.
First off, the O-Rings to get are CAC 5118, I got them from my
local dealer, who charged me 11.92 for four o-rings (Only needed
two, but didn’t want to make a second trip if I pinched one or two
and ruined them), including 6% sales tax. If looking for them
elsewhere, they are 20mm ID, 26mm OD, 3mm cross section.
From opening the hood to starting cleanup, the job took 1.5 hours.
I’m careful, but not obsessive, and I’ve taken off the intake and
throttle body once before, so I’m not a complete novice with this
car.
I used a sharp utility knife to pry under the o-rings, which
promptly cracked and came out. They were very brittle, and clearly
in need of replacement.
All in all, pretty simple job, just annoying to get into the tight
spaces.
Good luck,
Edward
'92 Sovereign–
Edward Crane
Teaneck, NJ, United States
