In reply to a message from Brazierje sent Sat 21 Jan 2012:
Mmmm… There’s something wrong here.
The factory manual gives the torque for the cam cover screws
as no more than 3 Nm which is 2.213 lbf/ft which is 26.5 in/lbs.
If you applied 100 inch/lbs you over-torqued them!
I’ve never used a torque wrench on those screws. I’m
conceited enough to think that I can judge when they are
‘tight enough’ to avoid crushing (‘squishing’) the rubber
gasket.
One thing I did learn the hard way is that some of those
screw holes in the head (the front two?) are ‘blind’ holes.
You have to ensure that they are clean and dry before
fitting the cam cover because if you get any oil down those
blind holes the screws tend to ‘hydraulic’ and you think
they are tight enough but in reality they are not and you
get a seal leak.–
In the Haynes manual the torque for the cover screws is 89 to 106
in-lbs. I torqued then to 100 in-lbs, the two forward center screws
didn’t make it. (I said a few choice words when it happened)
I’ll clean up the area with a Dremmel and try the JB weld. I the
meantime I’ll look for a replacement just in case.
Bryan N, '91 Sovereign 4.0 L, RHD
Cambridgeshire, United Kingdom
