This has to be a very common problem with these XJ6 Jags.
I purchased the replacement sensor, however, I am having the
worst time getting the old one out.
Is there someone out there that has done this successfully?
I’m cut-up, banged-up, dirty, and in need of some guidance.
I’ve removed the oil filter, but there is no room to get to
the sensor.
thanks in advance, you’re a great group of guys!–
loki1
As you say, a very common problem on these XJ6 Jags.–
the sensor.
I assume you are trying to remove the original style (the big one).
The best way I found was using a crowfoot wrench and coming in from the top. However my Canadian car has no air pump and others tell me that it gets in the way from the top.
If you want to see what I mean by a crowfoot wrench here is a picture.
In reply to a message from dboarder@sympatico.ca sent Thu 20 Apr 2006:
from under take off the oil filter block 4 bolts. then its much
easier. pajtas–
jaguarjoe 54 XK 120 rdstr 1961 MKIX 94 XJ6
