I was feeling good about having found the source of my
battery drain (a recent forum thread: I removed the lock
heater relay and the drain went away). Drove the car about
15 miles yesterday to have lunch with a friend. When I went
to leave about 90 minutes later, the car wouldn’t start. It
would crank like crazy but not even a cough.
The tach wiggled slightly as I cranked so I assumed I had
spark. I tried to hear the fuel pump run when I turned the
key on but couldn’t (hard to tell over the blare of the
warning horn and the noise of the attack belts running). I
removed the fuses for the attack belts, still heard nothing
but the warning horn. I happened to have a Philips
screwdriver in the car so I removed the passenger knee panel
and tried swapping the fuel pump relay with another one. And
another one. Still no start (altogether probably 12+ tries
over a 2-hour period, battery still strong, no console
warning panel clues). Not a lot more I could do alone and in
my good clothes. Debated whether to call a local junkyard
and have them come get it (this crap is getting tiresome).
Finally gave up, called AAA and had it towed to the shop on
a flatbed truck.
Shop called today and said he’d installed a fuel pressure
gauge and no fuel spilled out while he attached it (it
normally would spill some, so that’s a clue it might be a
fuel pump issue). Then he turned the key on and the pressure
reading went up to normal. He turned the key to Start and
the the car instantly started. It probably would have
started when the tow truck dropped it off, I’ll never know
for sure.
So, now I have an intermittent failure, likely electrical
and if I drive it, I may end up having to have the car towed
again.
Arrrggghhhh!–
84 XJS, 89 XJS, 89 XJ40
Santa Barbara, CA, United States
