In reply to a message from Bryan N sent Tue 18 Sep 2007:
Having experience seeing and trying to remove nuts on agricultural
tractors/tools and off road cars, I can say that there are two
options to remove a tight nut: with an air operated impact wrench
or with a long tube that increases the arm lenght of the
ratchet/braking bar.
The position in which you are trying to remove the nut is also
important, so if the car is in a lift or one has a well in the
garage (like some shops have), that will make the job easier.
I’ve seen large nuts, in excess of 1’’ size that were almost welded
by dust, rust and lots of junk, removed with large (1+ m lenght)
steel tubes. That tubes are part of the tool stock in any descent
farm workshop, you can’t imagine the amount of impossible to loosen
nuts one can see in the course of a year at those sites. A stock
of strong arms and hands are also highly recomended
I suggest to use WD40 or some of the spray and pray stuff in large
quantities some 24-48 hours before loosening one of those tight
nuts and repeat the application every 4 hours during that period.
Is a good idea to use antiseize stuff when refitting the nut (a new
nut is highly recomended). Always try to keep the bolts as clean
as possible and covered with a thin film of oily product, that will
avoid extreme corrosion.
The cleanest tractors are the easier to mantain, ask to any John
Deere/Caterpillar/JCB/whatever technician. Thats why I use to
clean the underbody of my car with the pressure washer at the gas
station. Mechanics are surprised how clean the car is from below,
almost more than the body or the interior :)–
Huaorani Warrior, '92 XJR 4.0, manual gearbox, VIN 653523
