In reply to a message from agrossman@pacific.net sent Thu 15 May 2014:
Groove
Did this myself a few months ago - very pleased with result
The braking appears a little more sensitive at light
braking but does need a little more foot power when heavy
braking needed.
The space in the engine room is amazing now that everything
to do with the ‘old’ system has gone - can now actually see
the steering motor and the ac compressor, also the front of
the engine in way of the CPS is now easy to get to
The main concerns I had were the following _ drilling and
tapping the inlet manifold for the vacuum takeoff - there
was a ‘blank’ near to the vacuum takeoff for the vacuum
tank driving the ac solenoids so just removed the inlet
manifold ‘loop’ in that area and stuffed a rag in there to
catch the drilling and tapping waste so it did not get into
the inlet itself - turned out to be a lot easier than I
thought it would be.
Some have mentioned that the existing takeoffs for the
vacuum that are already on the inlet manifold would be
enough to drive the booster - personally don’t think it
would do the job and I believe you need a dedicated takeoff
with larger diameter hose - when you compare the size of
the booster itself, the size of the hose connection on the
booster and the size of the existing takeoffs then you will
see what I mean
The other point is that before the master cylinder can be
mounted to the vacuum booster you have to drill the holes
out a bit as the booster bolts are bigger then the
hydraulic system bolts.
There is a good write up on what you have to do in the XJ40
book - follow that and you wont go far wrong
Im very pleased with the result, car just went through the
government annual test here last month and the testers
never noticed, brake response on the test rig was excellent
All I can say is do it and not worry about the green oil
any more, let alone the gas bottle !! - the blank for the
front engine casing where the hydraulic pump outlet is
mounted is available as a jag part - sorry cannot remember
the number but it cost a peanut or two
Best luck and if you want any other guidance just email me
direct
Nigel–
1987 XJ40 3.6 Auto Sov SAJJHALH3AA512874
Singapore, Singapore
