I was told that my jags engine 3.6 may be replaced with 4.0.
How can I find if I have 4.0 engine?
Thanks–
Jaguar xj 3.6(maybe 4.0) '87
Find us at http://www.xjjaguar.co.uk/
Call (+44) 01323 740471 or (+44) 07745 713940 ( 0900-1800 GMT ONLY)
To: xj40@jag-lovers.org
Subject: [xj40] What is the difference between xj 3.6 and 4.0 engine.
Date: Sun, 13 Feb 2005 12:04:00 +0100
Thanks
In reply to a message from Robertas24 sent Sun 13 Feb 2005:
Here’s a reprint from the archives of a post I made about 10 days
ago:-
‘‘Look at the engine serial number stamped on a web on the block on
the right side near the front behind where the distributor fits. If
the second character is a ‘D’ it is a 3.6, if an ‘E’ it is a 4.0 -
or it may be a ‘B’ in which case it is a 3.2.’’
But as Phil says, unless someone has swapped engines in the past,
an '87 XJ40 will have a 3.6 (or if SOHC, a 2.9)–
Bryan N, temporaily exiled in Fl minus '91 Sovereign 4.0 L
Cambridge, United Kingdom
