In reply to a message from alfiepanda sent Wed 18 Feb 2009:
Couple places I’d check.
Verify clean, tight battery connections. Do things like the
headlamps, wipers, interior fans and radio still work?
Inertia switch. Drivers side footwell above the fuse block.
Verify the security system has not immobilized the car.
Verify the Neutral Safety Switch is working correctly.
Check the starter relay. One of 4 built into a relay pack.
Under the dash, passengers side blue base. Very easy remove
the cover of the relay pack and manually close the circuit.
EMS Main relay, under the bonnet, passengers side of the car
on the firewall. Black base.
Fuel pump relay. In the boot, right side of the car, just
forward of the tail light behind the carpet trim.
O2 Sensor Relay. Under the bonnet, passengers side of the
car on the firewall, yellow base. This powers the fuel pump
relay!
Ignition ON relay. Under the dash, passengers side black base.
Crankshaft Position Sensor. Very front of the engine, just
above the crankshaft pulley.
Good luck!–
Hi all…HELP needed! before have to scrap!. I have a 94
Daimler 4.0L. It was running fine- never had a problem only
done 80kmiles and FSH. Parked it up and left it for about 3
weeks. Then tried to start it- turned over fine but would
not fire. Checked all the usual but no joy. Ran battery
down trying to start it. Took it off to re-charge. Put it
back on but battery now no good- wouldnt even turn it over.
Had car towed to garage. They tried a new battery on and
now tell me it won’t turn over at all !!-seems seized.
91 XJ6, 93 Sov, 97 Sov – Driveway’s crowded!
Tampa Fl, United States
