It’s not an easy job Robert but with care it cone be done, and a job I wouldn’t trust any shop to do.
The screens are glued and the inox trim is embedder in the glue.
The trick is to do it in two parts, i.e. first glue the glass and leave the rest of the channel free of glue so you can install the trim afterwards.
You will need new seals, all three, and buy a pair of special screen handles.
Also buy more glue than you need. It would suck if you run out of glue half way…
Also a very good opportunity to check, and if needed repair, the channels for rust, a very common problem.
Scroll down the thread. It’s for the rear screen, but the principle is exactly the same.
