Can someone explain how the return spring on the throttle pedal of a xj6 s3 1982 is set up. I have play in the throttle pedal when moving from no throttle. Having a look at the pedal the spring seems to be doing nothing.
Should the 2 tabs either side of the spring be bent outwards (see photo) ?
What holds the spring in position ?
Thanks for any help.
