But problem did not return - and what did you actually do with it? Hardly likely to have been the pressure regulator, but did you change that? And could the problem the same as for Simon…??
After all, we do not know positively that the regulator is the culprit in his case.
Anyway, if fuel leaks out of the regulator vacuum hose; the regulator is defective…
My problem was likely electric. I’ll never know what it was. Memory forgiven!
Simons knows what the problem is, that the regulator is faulty and it is clear what caused the gasket failure.
Hi Frank, in this case the regulator was the cause without any doubtI was unfortunate in that the carr aattempted to start which was the final nailin the proverbial
