XJ6 SU jet sticking after rebuild
XJ6 S1 twin HS8 SUs with manual choke.
I’ve rebuilt the carbs.
Now the jets stick down when I use the choke and won’t pop back up.
Any suggestions?
There can be a couple of reasons for this
a) some fault in the way you have built your choke mechanism, such as a loose fastener
(I had this)
b) the jet is misaligned and/or sticking within the carb body (or on the needle)
I cant remember whether the HS8 have a spring that pushes upward on the jet from below like an HD8. I replaced the HD8 Jet springs on one of my vehicles with stronger SS springs
I corresponded with a guy that was very experienced with all sorts of Jags, and he noted that sticking Jets on HS8 manual choke setups was a known issue
I have had this happen with a new jet on my e type (HD8). The top edge of the jet had a very small burr on it which made it stick in the jet bearing and not come back up on releasing the choke. Would be surprised if you had two like this, but not impossible. My conclusion was the jet had taken a small knock during handling before I got it. Was able to carefully dress the jet with a fine file to remove the burr. Was hard to see the damage but you could feel it.
Hi Andrew, I put a helper spring in when I changed over from the AED to a manual choke on my HS8’s. Takes a bit more to pull the choke out but I know for sure that the jet “bottoms” to the warm driving position when I push the choke back in. Paul.
Driving me nuts.
I spoke to Midel twice today. Unhelpful would politely describe the interaction.
Tony it’s entirely possible I put them together wrong, but I did do one at a time, using the complete one as a template. Yes they do have the “baby bouncinet” spring arrangement, which looks suss to me.
Dave I’ll have a look for burrs.
Paul can you send me a photo of your helper arrangement?
Otherwise, she runs like a beast! Did a 140 mile run on the weekend. The 4.2 engine is great. I have (I think) a 3.77 diff and a Toyota W55 5 speed box. It will pull from 60kph in 5th comfortably. Can’t wait til I can wring it’s neck.
Now if I can just sort out all the rattling timberwork in the roof… anyone know what’s inside the factory sunroof?
What’s your rpm in 4th at 100 kph? If it’s 3000 it’s a 3.54, if it’s a little more it’s likely a 3.77, must be really quick!
If it’s the original differential and the car number ends in DN it should be 3.77 otherwise more likely to be 3.54.
I thought about centralizing jets but not sure if they can be/ have to be centralized, bent needle or a swollen gasket or a weak return spring - does it happen without the needle in place? Can anything be lubricated?
Not really a question of “putting it together wrong” as the HS8 doesnt actually have a manual choke, its just they can easily be adapted to accept one
Its pretty critical the Jets both move in unison or the vehicle runs poorly
It helps to have an assistant operate the choke lever while you observe the movement of parts, this can be done without taking anything apart (initially)
Its usually only one that is sticking
I think my adaption is different to yours, but like Paul, I have a helper spring to assist return of the Jets to their original set height
I have confidence you will sort it out fairly easily :smiley:
on mine, one of the fasteners on the levers that run of the rod that connects the choke levers was just not quite tight enough. I spotted it in 30 seconds, as you could see one moving and the other not, I think they are Whitworth size. I have a set of small Whitworth spanners
Thinking about it a little more, a couple of things
I presume you used new jet assemblies, as you mentioned Midel
The reason I say this is I found one of my HS8s had a sticky jet mechanism, and that I would need to buy a new one (that is for the triple set on a 420G manifold, I presently have an XJ6 motor and inlet, twin carbs in my 420G)
In addition, as far as I remember, the Jets wont return back to the initial position without a helper spring, they are not designed to, and they dont have a spring pushing the Jet underneath like HD8
I will send tonight.
David,
I always thought the XJ6 with o\d had a 3.77 diff like the Mk2 and S Type, but according to my owners manual, manual and auto cars have 3.31 and o\d is 3.54. May be different for US market. IIRC 3.77 diff gave 20mph per 1000rpm in 4th ( direct) Book says 21.7 mph\1000 for 3.54 , 20.4\1000 for 3.77 and 26.5\1000 for 3.77 in o\d. Owner’s manual says 60mph = 2172rpm in o\d with 3.54 diff.
It definitely changed depending on market and over time. For example, I have an 3.54 auto from France: that’s the standard ratio but you could have ordered different ratios. I’ll try to out an overdrive manual in there and hope that 3.54 is high enough as it has more than enough power. 3.77 is listed as the standard for o/d cars in my manuals. I think his transmission is direct in 4th and overdriven in 5th, so I asked for the direct ratio.
Maybe the 3.4, 3.8 didn’t have enough torque to pull the 3.54, hence the 3.77. When I converted my 3.4 Mk1 auto to manual, it would only do about 90mph flat out in o\d, that with a 3.54. I had a 1971 or 1972 man o\d S1 XJ6 about 40 years ago , and vaguely remember it being geared much the same as my S Type (3.77) so perhaps they changed back to 3.77 from 3.54 to give bit more mid-range. My owner’s manual claiming 3.54 for o\d is a 1970 manual.
My 72 XJ6 4.2 auto (Australian delivery) has a 3.07 diff. As you say market dependent.
I don’t know why the 3.77 for factoy O/D cars. My Mk2 - a converted MOD - will pull cleanly in O/D from 40mph. It’s a 70,000 mile 3.4 litre.
PS: It’s got a 3.54 diff.
Andrew. My manual choke only works the rear carb. The bowden cable is mounted through a ferrule on the carb body. Choke pulls on the mixture arm and the link pulls on the idle lever. The helper is mounted on top working opposed to the choke cable action. Perhaps you could do similar - expect yours would work both carbs. I think Tony’s works both from memory. In the picture the choke is out about 1.5cm - pulled away from the bottom of the mixture screw and both the idle screws per link rod.
I can’t recall how well mine pulled from low revs in o\d, but it just wouldn’t pull high speeds; overgeared. IIRC it was close to 30mph\1000rpm, so 90mph was at max torque. If you took it past that in top and then engaged o\d it would slow down.
Really?
I don’t have my manuals with me at the moment. The workshop manual quotes optional final drive ratios in the final drive section.
The 4.2 OD is supposed to go over 200 kph (like the S3 auto with the 3.058) whereas the 4.2 auto and 4 speed will not see 190 because the diff is too short. My guess is that the 3.77 made the cars quicker while not fully sacrificing fuel economy, so the o/d gave you a more powerful car.
My 4.2 auto hasn’t seen 4000 rpm yet but it goes pretty well and can definitely take another gear. Plus with the auto starting in second gear is bearable so to me and for my taste, it’s geared too low at 3.54.
30 mph/1000 rpm is low but I just can’t see how that is dramatically overgeared, then again top gear is the intended performance gear (direct, less losses) and overdrive is more to reduce thirst and noise. I‘d like to turn 2000 rpm at 60 like modern cars do!
IMO, a single choke operation gives an advantage in reliability
(having experienced this when mine malfunctioned), in that the vehicle will start and run like that, just wont perform as well while choke is in use, which is somewhat ambient temp & load related, but could be 30secs to 3min, or sometimes longer
With the dual choke setup, if a fault develops its more likely the Jets can get stuck in such a way as the vehicle runs very poorly, needing roadside attention
There a more than twice as many “non-original” parts in the dual choke system
If you are a perfectionist, a properly setup dual system may be desired
I really like the way mine works during warmup period
I went through this dilemma with my tri-carb HS8 setup
2 is much easier to do, as you can use a standard Jag V12 choke cable
Slightly bent needles. Decades ago on an sU in an Austin!!!
