I am looking for XJ6 differential sun gear - does anybody know if there is someone still supplying these parts?
SC Parts say they have them, but the price is unreasonable, besides they may actually not have it.
Tadek
Tadek
The ‘CROWNWHEEL & PINION’ must be a PAIR. (manufactured as a pair)
I have never seen them sold separately.
Common ratios are…
2.88:1
3.07:1
3.54:1
You are very correct motorcarman.
However, a sun gear is something else.
Tadek
Sorry, I thought you meant the ring gear.
I have heard of them referred to as ‘planetary-gears’.
Should be a bunch of good used ones. I should have one in stock, but will need to tear down a diff to get you one.
The input gear in a differential is called a pinion gear. The other is the ring gear.
Tadek, I sent you a private message regarding this.
Rob
Thanks Robert, Jeff
Robert I will get back to you when I come back home on Monday - many thanks!
Jeff, many thanks for the offer - seems Robert has some loose ones.
Many thanks for support!
Tadek
