hi all, when i switch on the front fog lights the little light on the switch comes on as do the lights. when i do the same with the rear light switch no light on the switch and cant see any lights at the back. are these built into the rear cluster or not? thanks.
Yes, built into the tail light cluster. About the same intensity as the brake lights
DD
hi, ok thanks, will check them out.
you will probably need to have the headlights on or the front fogs to enable the rear fog lights
hi, yes found i need the headlights on but only the sidelights for the front fogs seems weird to me.
An attempt to prevent the rear fogs being on when not required
