Hi does any one know where I can get a protective replacement “ boot” for an XJR15 anti stall solenoid ( they operate on the front end of the throttle spindle)? I’ve been lead to believe they were USA manufactured. Unfortunately the only information on the solenoid is: 0345 & 60/90 - no makers name.
Nigelplug - without a part number for use of search, a “Google” search for “anti stall solenoid boot cover” will bring up samples that you may be able to use to compare for what you need - Tex.
Thanks I’ll try this.
Hope it helps - post a follow-up picture if you do find something that works - Tex.
