Seven months on and I thought I’d give you an update. I’m pleased to report that all is well.
After replacing the AAV and ETS which did manage to get rid of the surging, I decided that the rear fuel system, including the surge/sump tank had to come out.
I used the drain on the bottom of the surge tank to drain the car’s fuel after loosening the tank’s 3 retaining bolts (fuel pump had already been removed). The much hyped 11/16 spanner wouldn’t budge the nut after 35 years - so a same size socket was introduced up through the drain hole and with a big pull, it loosened.
The tank was removed and this was the state of the filter which pretty much mirrored the interior of the tank, There was no oily/fuel gunky reside clogging it up but what I can only describe as very fine, limestone-like dust resembling lime-scale.
This came out of the filter.
I used a solution of salt and vinegar to clean the tank interior and with a clean vent tube and new filter
all was reassembled.
Getting the tank back in to align the bolts with the threads on the flanges on the underside of the battery tray was ‘challenging’ (never, ever allow anyone to mention ‘precision engineering’ and ‘Jaguar’ in the same breath) but with everything back in place, HT lead back on the coil, ‘85’ back in the relay and battery connected the moment of truth - turn on the ignition, expect short delay before the 3 second run of the fuel pump and…nothing, just the engine cranking!
I was sure the pump was wired correctly so I went to the relay. ‘85’ was difficult enough to get out and I gave it some more ‘shove’ to make sure it was fully located. Back to ignition, whirr of fuel pump, and around 10 seconds later - all 12 are firing - hoorah!
But had the problem been cured? I’ve taken her on 2 test runs and she has behaved faultlessly: everything is working perfectly. So whether it was a dodgy fuel pump or a fuel pump made dodgy by the clogged filter? I’d suggest the latter.
Take from this saga what you will. Cheers everyone!
