Want to keep stock fan and add electric fan in front of radiator. With air cleaner located there only 10 inches of clearance for an electric fan. Suggestions from those who have addressed this issue.
Thanks,
Gust Nelson
Thanks,
Gust Nelson
I found one at a scrap yard, a Bosch from a Mercedes.
I don’t actually use it very much, just when I get stuck in traffic on a hot day.
a hot day in traffic cooling trick…install, hidden where you like., .mine is up inside the front wheel well, …a small electric window washer pump with its water container…run the tube to the radiator front in vicinity of aux fan, with a fine spray nozzle…switch aux fan on and press washer pump button a few times…to drop temp temporarily.
Nick
