In reply to a message from Thornsdale sent Tue 28 Jun 2016:
Bob,
That the pertronics didn’t improve things would seem to
indicate that your distributor is no longer in order.
If you want to stay original, then send your dizzy to
distributordoctor.com Martin’s work is to the highest standards
(in my experience) and he will return your distributor to
exactly the same spec as it was the day it left the factory.
If you fit a 123 distributor you will have various advantages.
If you take a 123/tune, you can set the advance and vacuum
curves yourself, as well as a rev limiter, and store two sets
of maps, which you can select via an external switch (ie, you
can have a regular and a race map). I’ve installed a few 123s,
I particularly like the TUNE variant.
Not burning the points out if you leave the ignition on is a
benefit, as is not having to replace points.
Having a rev limiter is worth it, in my opinion. Even if you
trust yourself completely, the rev limiter still works if you
lend your car, or if a joyrider takes it for a spin.
The downside to the 123 is that if it fails internally you will
not be driving the car home. Keep your original Distributor in
the boot - this good juju is a guarantee that the 123 will work
forever (same goes with a spare fuel pump).
Andrew–
This failed to make any improvement and after much
googling and talking found that everyone who ever
installed a 123 never regretted it, so I am about to try
that option.
1968 3.8S
Zurich, Switzerland
