I’m looking to replace my original Rad & Fan. Looking at an aluminum rad and multi blade fan. I no would appreciate any suggestions or comments regarding. Thanks, Paul
Using the spy glass, top right, you can search on ali rads, depending where you are based might change the responses, you can add a country flag to your avatar, again top right of the page, as this is a world wide forum.
I installed a Ron Davis aluminum radiator in my 58 150 OTS. It was custom made using my original radiator as a pattern. Now he has made one, you can order on his website.
