Roar,
I was a little unsure when making my comment, and too lazy to check, but in
back of my mind I seem to recall that USA uses a different convention/method
of determining octane rating of fuel than is used in both England and
Australia (and other “British Colony” countries).
Equally, I believe what was standard in England in 1950s is different
methodology (thus ocatane number) than is used today, so makes it necessary
to compare apples with apples to make any sense out of this.
In the 1970s and later, in UK “FIVE-STAR” fuel was available and is what is
required/recommended for a 9:1 cr XK engine - with FIVE STAR being 100 RON
octane. I think (and our UK listers can correct me), but 4-STAR fuel was
97/98 RON and only useable without “pinging” if you retarded ignition from
optimum (with resultant overheating/fuel-consumption risk) ( I purchased my
E-Type 9:1 cr in UK in 1975 and drove it around for 9 months happily on
FIVE-STAR, but NOT on FOUR-STAR).
In today’s terms, in Australia at least, we have three main fuel qualities
available 91 RON unleaded, 95/96 RON “Premium” unleaded and 97/98 RON
“Ultimate” unleaded with anything more only available through special
racing-fuel/aviation fuel outlets or octane-enhancing additives to be added
to your fuel.
A 9:1 cr engine will operate satisfactorily on 97/98 RON “Ultimate” if
engine is carefully tuned and in good condition, or if driver just ambles
around not using full performance capability. 95/96 RON is unsuitable.
A 8:1 cr engine will operate perfectly OK on 95/96 RON under all
circumstances, or again if driver just ambles around, can get away with
using 91/92 RON.
A 7:1 cr engine totally happy with 91/92 RON.
In the real world (in Australia), all outlets tend to offer both 91/92RON
and 95/96 RON, but only selected outlets offer 97/98 RON and in country
areas (rather than major cities), 97/98 can be difficult to find.
So practical everyday usage 8:1 cr engines have no trouble sourcing 95/96
RON or if caught out can get by OK with the occasional 91/92 RON fuel.
A 9:1 cr car is constantly aware of need to access 97/98 RON fuel.
And of course there is a price premium for 97/98 RON fuel compared with the
lower-octane fuels.
If you live in cities and don’t use XK engine often, then accessing 97/98
RON is not overly taxing/expensive so liveable, but if you drive/tour in
country/remoter areas it most certainly can be a problem.
If you are saying in US that your “Premium” unleaded is 93/94 R+M/2 octane,
would suggest that your octane rating methodology is different to ours and
UK’s, and of course I have no idea what that means in practice in US re
availability of higher-octane fuel - some 20 years since I last drove
extensively in USA and that was just in “cooking” cars and not an XK.
Will have to look and see if there is some direct correlation between
different rating methods, but one thing that is not relevant to todays fuel
availability is the 1950s “Research” method ratings as quoted in Autocar
magazine.
But as before - the practical reality in Australia is 8:1 cr presents no
problems/issues with 95/96 RON fuel availability, but 9:1 cr does create
ongoing difficulties/problems, and in UK (been a few years since I was
driving/buying fuel in UK - so don’t know current situation) FIVE STAR fuel
in either no-longer available, or has limited/restricted availability, with
FOUR-STAR being the “Premium” fuel available. Our UK listers may care to
bring this comment up-to-date.
AND while talking about all of this XK engines do not in any way care
whether fuel is leaded or unleaded - its a matter of octane rating ONLY,
despite many vendors (in Australia at least) making money suggesting a need
to modify valves/valve seats or use additives to be “unleaded” acceptable,
although these days, problems with added 10% ethanol to 91/92 RON “unleaded”
is more of a concern than the old leaded/unleaded concerns.
Roger Payne - XK140MC OTS; E-Type 4.2 S.1 OTS; DSV8.
Canberra.-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
Roar Sand
Sent: Wednesday, 25 August 2010 9:00 AM
To: xk@jag-lovers.org
Subject: RE: [xk] 54 Engine rebuild
Roger,
I am a little confused by your statement:
The theoretical 5-10 hp gain is unlikely to be
achieved, if in fact a driver could actually tell anyway,
unless all other
aspects of engine and driveline condition were in 100%
as-new condition and
state-of-tune, but they would constantly have issues with
obtaining the 100
octane fuel required to optimise their 9:1 cr needs.
The report in Autocar, previously mentioned, claimed that 85 to 90 octane
fuel was needed for 9:1 compression ratio XK engimes, and you say 100.
Granted, neither are specific as to whether the numbers represent “Motor” or
“Research” method, however, my engine with 9:1 and “B” head seems to run
nicely on our unleaded premium fuel, which runs at 93 or 94 R+M/2 octane.
Admittedly I have not checked to see what basic spark advance is set at by
the shop, but I do know that the carbies are jetted on the rich side, based
on the fact that I have yet to achieve significantly over 13 MPG, or 18
liters per 100 km.
Roar
