I am trying to get the end float right. The original thrust washers give
end float of about .008". The Service Manual says it should be .004 to
.006. I tried replacement standard thrust washers that give me almost no end
float, certainly less than .004.
Should I re-use the original thrust washers or use the standard thrust
washers?
End float is important. I suggest “adjusting” the end float on the new
thrust washer with a little file work or compound and plate glass.
Guys,
end float, certainly less than .004.
washers?
In reply to a message from john shuck sent Mon 29 Oct 2012:
You have probably sorted out your problem, But, there are two sixes
of washer, use the two (new or old) that give you the correct end
float.–
Manny 1
In reply to a message from SUEUM@aol.com sent Mon 29 Oct 2012:
Frank
It’s unlikely the thrust spread on your crankshaft got
smaller over the years, so I would put in the standard
washers. It takes a fair amount of pressure (not just
pulling the crank by hand) to determine the end float. Put
in the standard washers, and use a pry bar or long screw
driver to move the crank back and forth. I would guess the
end float will be .004’’ to .006’’. The new washers will ‘‘run
in’’, and give you a little more float.
Joel–
ex jag, '66 E-type S1 4.2, '56 XK140dhc, '97 XJ-6
Denison, TX, United States
In a message dated 10/29/2012 7:46:37 P.M. Eastern Daylight Time, jcrprops@sbcglobal.net writes:
In reply to a message from @SUEUM sent Mon 29 Oct 2012:
Frank
Joel–
