[xk] DR3 Wiper Motor Wiring
Does anyone have an internal wiring diagram that includes the
correct connections to the posts inside the casing? I managed to
get a motor that has no internal wiring and my original motor
wiring is burned beyond recognition. Having no electronic wiring
background leaves me with not much internal help. I WILL need a
picture.
Thanks–
150 DHC
Auburn, CA, United States
Dear Jaginabox (first name would be nice),
  1. Red - Armature B plus parking switch. Other side of parking switch is
    grounded.
  2. White - Field coil non resistor end
  3. Orange - Fast speed resistor
  4. Brown - Field coil plus resistor
  5. Blue - Armature A plus thermal circuit breaker
  6. Green - Circuit breaker. This connection goes to supply. Don’t know if it
    ignition side or not on a 150. Suspect it is.
I can tell you connections to the switch if you need them but it depends if
you have a PRS7 or PRS5 switch
Eric
Church Stretton, UK----- Original Message -----
To: xk@jag-lovers.org
Sent: Tuesday, December 30, 2008 6:08 PM
Subject: [xk] DR3 Wiper Motor Wiring
picture.
Thanks
150 DHC
In reply to a message from Eric Capron sent Tue 30 Dec 2008:
My greatest thanks to Otto and Eric. I now have pictures and
explanations. I will post on list when I am finished.
Frank–
150 DHC
