[xk-engine] Big valves
Do all F/I engines have the bigger valves? or does that start at a
certain year or engine #? Thanks Nick–
Nick Hand
//please trim quoted text to context only
In reply to a message from Nick Hand sent Fri 11 Mar 2005:
Hi Nick,
I believe the bigger valves first started on the series 3 xj6 4.2
motor. I know that the series 3 came with F/I, but I am not sure if
the series 2 had it or not. I am not that familiar with xj6’s. hope
this helps some. Is there anyone else out there who cane help Nick
out.
Dee-Jagman–
dee-jagman
In reply to a message from dee-jagman sent Sun 13 Mar 2005:
Thanks ,I had a reply off line . That said ‘‘big valves began with
series111’’. Nick–
Nick Hand
In reply to a message from Nick Hand sent Mon 14 Mar 2005:
Where are you Nick?
Fuel injection also began with the Series 3 XJ6 in the UK, which is
why any 4.2 EFI head here has big valves (and ports), whereas in
USA some late Series 2 cars had EFI but not the big valves or
ports. UK heads were also never fitted with the air injection
system on the exhuasts AFAIK.–
Peter Crespin 94 X300 Daimler / 66 2+2 ‘E’
Buxton, United Kingdom
In reply to a message from Peter Crespin sent Wed 16 Mar 2005:
It is my recollection, as one who was present when it was under
development, that all production EFI XK engines, including those in
Series 2 US market cars from early 1978, had the big valve head.–
Roger Bywater / AJ6 Engineering
In reply to a message from RogerBywater sent Thu 24 Mar 2005:
Folks,
…some further confirmation of an unimpeachable source
(Roger Bywater)…
Since I just removed the head from my 1978 Series II XJ-6L
last Sunday, I can state that my early fuel-injected engine
has the ‘‘big’’ 1.875 inch diameter intake valves. While I
am not the original owner, none of the service history I
have from the previous owner indicated any valve work.
Regards to all,
Jerry from Alb’q
PS I’m re-posting this via the Forum as my original message
didn’t seem to get posted. My apologies if it’s redundant.–
Jerry from Albuquerque
Albuquerque/NM, United States
