In reply to a message from KeithB sent Tue 20 Mar 2007:
John:
I would add. It is extremely important that the engine builder get
the cylinder walls right. It takes a proper honing tool to get the
classic cross hatch marks. Some mistakenly use a simpler ‘‘glaze
buster’’. Sometimes the latter works and sometimes it doesn’t.
A compression test is a very good idea, open throttles, wet and
dry. That will tell you a lot.
Next and better is a leak down test. You insert the hose, pump up
the pressure. and close the valve. Watch the guage for the rate of
leakage. Usually found in performance store catalogs. Harbor
Freight probably has one or Summitt.
There are compounds to introduce into the oil to break the wall
glaze and allow the rings to seat and stop leaking. Some say they
work. They are an alternative to a tear down. I have my doubts.
Of course, unless you have oil puddles on the garage floor, it is
going into the combustion chamber in some fashion.
As Peter suggests, it may be a matter of over fill.
A classic break in was run the engine up on the RPM’s for a blast
then back off. Repeat several times. The back off is to allow oil
to be sucked in and lubricate & cool things down a little.
Carl–
It has been mentioned I think that getting the compression
rings to seal can be a problem. For running in, my engine
builder suggested short bursts of wide open throttle up to
4000 rpm with the engine well up to temperature - usually at
least 10 miles, to increase the pressure against the
compression rings and help the seat.
You have convinced me not to get my oil tested though…
Ignorance is bliss!
Carl Hutchins
//please trim quoted text to context only
