In reply to a message from Mark Eaton sent Wed 9 Dec 2015:
This statement is only partly correct . An engine producing
good torque at low rpm will not only be an advantage if the
shift point is at low rpm : it will be an advantage at all
times that the engine is passing through the relevant ‘‘fat
torque’’ rpm band . It is correct, however, that there will
be some loss of performance at high rpm, but this is usually
of less consequence in a road car . Incidentally, the B type
heads were devised to maximise torque in the low to mid rpm
range i.e. between about 1500 and 3500 rpm and the peak of
the torque curve was at 3000 rpm. The B heads were designed
to give good performance with the BW DG box introduced about
the same time . The straight port heads with 3 carbs and
the cams used gave a torque peak at 4000 rpm, and from
memory with 2 HD8 ( on the XJ6) gave a peak slightly lower
than that, say 3750 rpm–
An engine that produces more torque at lower revs will win the day only if
the driver shifts at those low revs … which may well often happen driving
around town, but will likely be less effective during ‘‘spirited driving’’ on
a back country road or race track.
christopher storey
//please trim quoted text to context only
