we are making a sizing tool like the churchill 17 and need
to know the diameters necessary to achieve proper clearances.
The archives talks about a v12 size but I do not see anything
for the straight 6.–
Jim MacLaughlin
Riverside, CA, United States
Sorry, but I have never seen one of these tools myself, and don’t have a
clue on the dimensions. However, do you know about the Tool Loan program
at the JCNA? JCNA acquired a lot of the factory tooling and loans the
tools out to members. There is a sizable deposit required, and a cleanup
fee when you return the tool. They list the tool below, which I believe
is the tool you are looking for:
J17 Rear seal sizing tool XK engines: This tool when used properly
ensures your XK rear oil seal does not leak. Use this and forget about a
modification to your crankshaft or a leak from an improper job.
One option is you can check the tool out and use it. Another option is to
check it out to use as a template to make your own tool, then return the
JCNA tool when you are done.
1990 Series III V12 Vanden Plas
1990 XJ-S Classic Collection convertible
1987 XJ6 Vanden Plas
1984 XJ6 Vanden Plas
1969 E-Type FHC
1957 MK VIII Saloon
Ramona, CA
P.M.Novak7@gmail.com-----Original Message-----
From: owner-xk-engine@jag-lovers.org [mailto:owner-xk-engine@jag-lovers.org]
On Behalf Of jmac
Sent: Wednesday, May 22, 2013 7:36 PM
To: xk-engine@jag-lovers.org
Subject: [xk-engine] churchill 17 sizing tool
we are making a sizing tool like the churchill 17 and need to know the
The archives talks about a v12 size but I do not see anything for the
straight 6.
In reply to a message from Paul M. Novak sent Thu 23 May 2013:
got the measurement needed to make the j17 sizing tool. I
will post these on forum after we successfully use it so that
others will have it in archives. Otherwise the Joc does rent
one and it is reasonable. Many have used other methods to
accomplish this task of setting the rear main seal and I hope
to not have any leaks this rebuild. Thanks all!–
Jim MacLaughlin
In reply to a message from jmac sent Thu 23 May 2013:
Sizing tool for 6cyl. jaguar motor was successfully made.
Measurements we used for big end is 3.12425 in. and the small
end is 2.917 in. Make a good taper. Email me if you need
pictures. Thanks jmac2mac@gmail.com–
Jim MacLaughlin
Hi Jim
Can you post the dimensions of the tool so i can reproduce one(including different length…I tried to email you but don’t seem to be able to…even after my donation …
Hervé
