Perhaps someone can help me with a problem.
Ford Dagenham I6 in a Reliant Sabre. Head gasket was leaking, was
replaced, compression etc was fine and car ran well. When we
drained the oil it wsa full of coolant. Contact with the PO
confirmed that the car had a history of magically rising Oil level,
which was what made us look at the head gasket in the first place.
After some running the oil was replaced again, and the engine
seemed to be fine.
A couple of months later the owner was out for a run, said the
engine started making noise and the O/P ‘‘disappeared’’, constant
highway speed, he killed the ignition immediately and rolled to the
side. Took the pan off, no sign of water in the bottom, not even
surface rust, not lumps of anything solid or metallic in the pan,
but the #3 conrod bearing was toast, badly scored and with bits of
black build up, the throw on the crank wasn’t all that bad. All the
other crank bearings were perfectly fine and measure -0.020 which
is what is stamped on the bearing shells. Oil passages are all
clear as far as we can tell. Oil pump had nothing untoward inside
it, and shows only little sign of wear (has been replaced at some
point judging by the appearance, pressure relief valve seems to
operate without sticking. No sign of a massive pressure loss
anywhere else internal or external to the engine.
Why would just one bearing go? If the crank or it’s feed had a
blockage or feed loss I would expect all bearings, or at least all
the ones ‘‘behind’’ the leak to show similar damage. Not having been
there it is hard to tell just how bad the O/P went, I have trouble
believing that a single bearing going south would allow so much
flow that the O/P would fall off all that drastically.
One opinion is that the #3 bearing was just waiting to go south,
and it did so more or less without being directly caused by the
head gasket change, so we should just replace all the bearing
shells and button it back up, presuming that the owner’s attention
was diverted by an expensive noise and wasn’t really paying
attention to the O/P gauge as things happened.
The other opinion is that things don’t generally happen without a
cause which is reasonably easy to trace empirically, even after the
fact.
Andrew–
1968 3.8S
Zurich, Switzerland
//please trim quoted text to context only
