In reply to a message from Anthony Strelzow sent Wed 19 Dec 2007:
Anthony,
Sorry, or rather pleased, that I don’t have the problem but
have been up the Weber learniong curve over the last 4 or so
years.
#3 is an option that is commonly employed by a couple of
sources - I think the 45 DCO 9’s had 4 progression holes. It
seems to be an effective fix to the issue.
I am running Webers (152’s with three holes) on a 4.2
engine, 9.4:1 compression and a Rob Beere full race cam 310
duration (although don’t know how measured) and .445 lift,
1.8 inlet valves and 1.625 exhaust valves. So is probably
sucking more air than the 3.8 so the specs may be irrelevant.
Also it is in my repro D-Type and the exhaust headers are
over the frame and 2’’ OD. So the breathing is probably a bit
different on the output side which no doubt influences the
air flow on the input side. One recommendation was to use
3.5 auxiliary venturies (instead of 4.5’s). Rest is 38 mains
and using 65F8 idle jets, main and airs are 160 and 190 in
F2 emulsion tubes. Don’t have the benefit of lamda sensors
but CO levels at idle (if the gas analyser is correct) is
around 2 which is surprising based on everything I have
read. I have used color tunes to set the idle mixture, you
get to see how even 1/8th of a turn makes a significant
difference, and have also just set them all the same based
on what sounds best. One thing the color tunes tell you is
if one of the chokes is significantly different which I
think could be an issue if you are, as I read it either only
sampling one of three of the front and rear exhausts or
maybe it is that you are averaging the front three and the
rear three. Haven’t worked out how to read them under load
and trucking down the highway though. My experience is that
if too lean they spit back at steady throttle just before
the main circuit starts to kick in. So a blend of a bit of
technology and seat of the pants.
I have run with velocity stacks but not having the problem,
cannot comment. Don’t routinely use them as I don’t want to
drag small dogs, birds and stones into the engine - the
latter is real, but I really need shorter than stock to get
adequate clearance on the bonnet in one place.
I did get some 70F8’s made at one point but the individual
jet specs is way beyond me.
Regards
Keith
Tempero D-Type–
#1/- Has anyone noticed improvement after installing velocity
stacks (50mm or greater). The idea here being to gain greater
laminar flow and increased velocity past the transition hole
drillings.
#2/-Has anyone tried biasing the fuel and air drillings on the jets
towards larger sizes to gain more mixture volume in the transition
pot/reservoir. (example: 65 F2 jets where the ratio of air to fuel
drilling cross sectional area might be similar to a 40F9 jet).
#3/-Has anyone tried drilling a fourth transition hole to
increase/smooth the enrichment on throttle opening. I have in fact
done so but would like to hear from anyone else that has tried this
Keith Bertenshaw
Rockaway, NJ, United States
//please trim quoted text to context only
