[xk] Head gasket
Dear XK-fellows
Some weeks ago I wrote about a waterleakage (through the overflow-pipe). I
seems like a worn top-gasket.
The gasket was not the old asbetsos/copper gasket, but a “simple” pressed
steel (?) gasket. The new one I got from my dealer is similar to the old
one.
Can anybody tell me if there is other and may be better types of gaskets?
And: it is recommended to use gasket sealant - a friend of mine mentioned
“3M Spray 90”.
Thank you
Martin
A friend of mine (not on the net) is restoring a 120. The engine block
(3,4) is original, but the top is from a 3.8 (Mk2). The job was done
properly , he told, but after a while the comp. blew into the
cooling-system.
May be a wrong gasket is the reason? He couldn’t remember what type of
gasket he used.
What type of gasket is recommended - a 3.4 or 3.8 gasket?
Any comments appreciated.
Thank you in advance
Martin.
PS: Some times ago I wrote about my bad brakes. After I filled up the
system with new brake fluid - no problem at all. My car runs great. (2000
miles this spring)
I wonder if this has anything to do with my leaking problem?
E.W. Blake----------
From: Martin Jacobsen martin.jacobsen@login.eunet.no
To: xk@jag-lovers.org
Subject: [xk] Head gasket
Date: Tuesday, May 26, 1998 10:22 AM
cooling-system.
gasket he used.
Martin.
(2000
miles this spring)
Is the increase in CCs from 3.4 to 3.8 from stroke or bore? How can you
seal a 3.8 chamber on a 3.4 hole? Just wondering JW
e. blake wrote:> I wonder if this has anything to do with my leaking problem?
E.W. Blake
cooling-system.
gasket he used.
Martin.
(2000
miles this spring)
The gasket installs dry.
Allan Pozdol
679474
