I’ve been collecting information and think I can now attempt to summarize
the history of oil filters. The C. numbers are Jaguar parts and all the
other part numbers are Tecalemit.
Early XK120 to engine W4382
Jaguar part no. C.2350, Tecalemit catalogue no. FA2045
The early XK120 filter canister #41518 was 7" high, 4" ID and made from .07"
thick steel. The bottom end is tapered with a 45 degree angle. The top was
flanged
out at a right angle to create a 3/16" lip which sealed against the rubber
gasket. It was held in place from the top by a 5/8" diameter bolt #101344
that measured 9 1/4" overall, had 14 Threads Per Inch and a 1" hex head.
There were apparently two variations on the way the spring plate in the
bottom was held in, by a big nut or by a circlip, though only the circlip
variant is listed in the parts catalogue.
The felt filter element FG2383 was about 5 1/2" long x 3-3/4" OD x 1-3/4"
ID.
The filter head #114042 incorporates two bypass valves. The internal balance
valve #50002 is fairly weak and, in the event of a clogged filter or cold
thick oil, permits flow from outside the filter to inside the filter and on
into the oil gallery in the engine block, which connects to the main
bearings. The external relief valve #49010 is fairly strong and, if the pump
is pumping more oil than the bearings can process, permits flow of the
excess oil from outside the filter directly back to the sump. On the angled
face opposite from the block face is an aluminum tag reading:
Cat. No. FA2045
Element FG2383
British Patent No. 501667
Reference: Urs Schmid p.86 #1; Porter p.90 far left.
Early Mark VII all A & B series to B5304
XK120 from engine W4383
Jaguar part no. C.4767, Tecalemit Cat. No. FA2678 (but INCORRECTLY listed in
the XK120 parts catalogue as FA2690/101)
The canister #41527 is 6" high, 4" ID, and with a 45 degree tapered bottom
end. The top end is flanged out with the same 3/16" lip as the previous
canister. The bolt #101620 is a 5/8" 14 tpi x 8" long, entering the head and
canister from the top. The felt element FG2388 is about 4-3/8" long x 3-3/4"
OD x 1-3/4" ID, described as a 17 star design.
The filter head is the same as the previous with the aluminum ID tag located
on the angled face opposite the block, but it has this information:
Cat. No. FA2678
Element FG2388
Reference: April 1952 Service Bulletin SB105, Urs Schmid p.86 #2; Porter
p.90 far left (head correct but has earlier canister).
Service Bulletin SB107 May 1952 reported that in a few cases the felt washer
under the top pressure plate had disintegrated and gotten stuck in the
relief valve, causing very high oil pressure.
1st midrange Mark VII engines B5305 to D6722 (with block C4820, steel sump
and new geared oil pump incorporating relief valve)
XK140 engines G1001 to G1907, but NOT XK120
Jaguar part no. C7438, Tecalemit FA2690
The canister #46160 is 6" high, 4" ID, and with a 30 degree tapered bottom
end. The top end is straight cut, not flanged out. The bolt #102298 is 7/16"
dia. 18 tpi and 8" long, entering the head and canister from the top. The
felt element FG2421 is described as 14 star and is interchangeable with the
previous 17 star cartridge. The filter head #114317 is a different casting
than the previous, with a narrower groove for a different rubber seal. It
has the same internal bypass valve #50002, but no external relief valve at
all is listed and the head is not drilled for it. Why? Service Bulletin
SB127 says it was now fitted in
the oil pump, confirmed in the Mark VII parts catalogue. The oil pickup pipe
was now fixed instead of floating, and there was a screen basket in the
sump. This filter head is only for the Mark VII and 140 engines listed; it
should NOT be installed on any engine that does NOT have the relief valve
inside the oil pump.
Reference: June 1953 Service Bulletin SB127, September 1953 Service Bulletin
134, Porter p.90 second from right.
2nd midrange Mark VII engines D6723 to N2941
XK140 engines G1908 to G6232
(D6723 and G1908 is the beginning of block C8610 and the rotary oil
pump
C8612)
Jaguar part no. C9936, Tecalemit Cat No. FA2690/101, there is a good
exploded view picture in the 140 parts catalogue.
felt element FG2421 is interchangeable with the previous cartridge. The
filter head #114317 is the same casting as the previous, with the narrower
groove for the rubber seal, but has both the internal bypass valve #50002
and the external bypass relief valve #49010, so it should have had a
different Tecalemit number.
The ID tag is on the rearward angled side, containing this information:
Cat No. FA2690/101 (the suffix /101 is hand stamped, not printed)
Element FG2421
Reference: February 1955 Service Bulletin SB161, Porter p.90 second from
left.
latest Mark VII from engine N2942 onwards
XK140 beginning with engine G6233
Mark VIII
Mark IX
Jaguar part no. C.11524, Tecalemit FA.2708, there is a good exploded view
picture in the Mark VII parts catalogue.
The canister is now #61874, and is bolted from the bottom, with a straight
cut top end and 45 degree angled bottom end. The bolt #103086 screws up into
a blind nut in the filter head, not listed separately. The filter head
#41034 has the same external bypass valve #49010 but no internal bypass
valve is listed. Was it eliminated or incorporated in the head assembly or
just forgotten by the catalogue typist? The element FG2421 is
Reference: December 1955 Service Bulletin SB175
XK150
2.4 Mark 1
3.4 Mark 1
Completely new design filter head, smaller canister pointing at an upward
forward angle.
The filter element FG2306 is 2.88 OD x 1.25 ID x 5.50 long.
Reference: Porter p.90 far right.
2.4 Mark 1 engine BB9001 onwards with steel sump
3.4 Mark 1
Jaguar part no. C12532
The oil filter had an external pipe from the relief valve to the rear of the
sump, and a blanking plate C12381 between it and the block, to blank off the
original oil return hole to the sump. The blanking plate could be
accidentally put on backwards, thus blocking off oil to the bearings.
Reference: Service Bulletins SB203, SB211A
2.4 Mark 1 from BC2256
3.4 Mark 1 from KE3054
Jaguar C12776, Tecalemit FA2720
This one has a dimple in the blanking plate to ensure it is not put on
wrong. It can be interchanged with the previous filter assy.
Reference: Service Bulletin SB217
Service Bulletin SB220 contains a summary of all oil filters.
XK150 commencing engine V6861
2.4 Mk1 commencing engine BE1582
3.4 Mk1 commencing engine KF7140
The blanking plate C12803 between the filter head and block is no longer
fitted, and the engine block modified with new drilled holes, new block part
no. C15951, and the sump was filed for clearance to fit the filter head.
Reference: May 1959 Service Bulletin SB266
2.4 Mk2 commencing BG5891
3.4 Mk2 commencing KG4675
3.8 Mk2 commencing LA7450
New oil filter assy C16296 with head pointing at a down and to the rear
angle, same filter element FG2306, has a balance valve and a pressure relief
valve.
Reference: SB B.8 11-60
Additions and corrections welcome.
Rob Reilly - 3/26/05
