Over to the trusty LUCAS Master Spare-Parts Catalogue - 400E (1945-1960)
HF.1748 is the MODEL of horn, but this model came in a number of variations,
as indicated by exact PART NUMBER.
70063 was available in A to F suffix variations, but suffix variations are
not functionally relevant.
A 70063 is described as 12 volt, and “Low Tone”, and finished in
Polychromatic Grey (whereas other HF.1748 were available in BLACK)
A 70071 (also available in A to F suffix variations) was the matching 12v
“High Tone” horn, again in Polychromatic Grey.
The Spare-Parts-Catalogue then provides individual part numbers of every
separate component of each Horn Assembly:-
Bracket, Tone Disc (flat or dished), Nut for Tone Disc, Washer cover and
diaphragm packing, Nut for diaphragm locking, Contact Set, Terminal Block,
Rubber Seal for Terminal Plate, and Sundry parts set - are all identical.
The only difference between a 70063 and a 70071 is the:-
DIAPHRAGM and ARMATURE assembly - part number 703726 (for Low Tone) and
703727 (for High Tone).
The 400E catalogue also includes detail photos, showing detailed photos of
every actual component, but there is only ONE photo - and this one photo is
labelled as being a 703726, 703727 or 690813 - so this tells you that the
actual difference between these three different DIAPRAGMS is not apparent in
a photograph.
The 690813 is actually the same diaphragm as used in a number of different
model WINDTONE horns, interestingly in both Low and High Tone pairs (thus
TONE variation is achieved some other way in Windtone Horns)
Back to the XK140 HF.1748 High and Low Tone horns - clearly the ONLY
difference is with the DIAPHRAGM - but given difference is not discernable
in a photo, then you need to have actual diaphragms in your hand to closely
examine to see what difference is, so OK if you are disassembling known High
or Low tone horns, but if you have a box of disassembled bits - GOOD LUCK.
Alternatively, you can always drop down to your local 1950s Lucas Spare
Parts outlet and order a new 703726 and a new 703727 to assist your 2011
rebuild!
Roger Payne - XK140MC OTS; E-Type 4.2 S.1 OTS; DSV8.
Canberra.-----Original Message-----
Sent: Tuesday, 24 May 2011 9:14 AM
To: ‘xk@jag-lovers.org’
Subject: RE: [xk] Horns
There is quite a bit of cross-purposes now dominating this thread.
The original thread was to do with XK140 horns - a Lucas Model HF.1748 which
came in two variations - the “High Note” (Lucas part no. 70071D) and the
“Low Note” (Lucas part no. 70063D). These are the FLAT appearance horns
Eric has been commenting about - and are illustrated/detailed within XK140
EXPLORED in Plate 7-e6. No detail provided of the internals however, and
short of pulling a couple apart, I cannot answer question asked, never
really looking for difference as my originals and a couple spares I have are
all intact and working, with identification tags still in place. Other than
the tag, there is no obvious difference on outside between High Note and Low
Note versions
The so called “SPIRAL” horns were not used in XK140 - but were used in both
XK120 and XK150. These are extremely common horns to find being used by
all manner of English vehicles throughout the 1950s. These are a Lucas
“Windtone” horn, or WT.29, with several minor variations including both Low
Tone and High Tone over the years. Urs Schmid’s book is on XK120 only,
thus the pictured horns are WT.29. These are slightly different on outside
and I seem to recall whether High Tone or Low Tone is cast on the inside
edge of the trumpet, but would have to dig out my stock of many spares to be
sure.
Canberra.
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
Bruce Cunningham
Sent: Tuesday, 24 May 2011 2:21 AM
To: xk@jag-lovers.org
Subject: Re: [xk] Horns
I searched in vain for my original horns with the crispy insides. I may
have discarded them. (I can’t believe I did that - maybe they will turn up.)
I did, however, find a picture (#3) of the horn on page 169 of Urs
Schmid’s r*****-covered book (The anatomy of a Cult Object - Volume 1)
clearly showing the spiral path for the air from the center of the
underside to the bell of the horn. Urs described it as "… black,
snail-shaped horn housings with their oval megaphones … ".
I do remember comparing the replacement horns with the originals and
noting that they both had spiral horns but with quite different castings
to produce the similar sounds.
Bruce
