In reply to a message from bobsxk120 sent Mon 15 Jun 2015:
I believe the cork seal was used with the cast aluminum
sumps, and the rubber seal was used with the pressed steel
sumps.
I always use Permatex No. 2 sealer for any gaskets that see oil.–
XK120 FHC, Mark V saloon, XJ12L Series II, S-Type 3.0
In reply to a message from bobsxk120 sent Sun 14 Jun 2015:
Use the cork with Permatex #2. Do not soak in oil.
Joel–
ex jag, '66 E-type S1 4.2, '56 XK140dhc, '97 XJ-6
Denison, TX, United States
I need to replace or repair the radiator drain spigot on our '52 120
OTS. I’ve been informed that they are not available as repros. Does
anyone have a good original that they are willing to sell to me or can
recommend a source for a replacement part?
For the time being, I have plugged the central hole in my spigot and
inserted it as a plug. I can simply remove it if necessary to drain the
radiator. It’s nice to have it back on the road again
In reply to a message from Bpp sent Wed 1 Jul 2015:
The XK’s site says theirs is not quite identical to original
and does not give a picture.
Be aware the thread is 1/2-20 ANF straight thread with a
fiber washer, so don’t put a tapered pipe thread plug in there.
There should be a steel coil spring with a small flat washer
on the bottom of the plug shaft. The order of assembly is:
plug shaft
large D washer
coil spring
small flat washer
split cotter pin–
In reply to a message from Rob Reilly sent Sat 4 Jul 2015:
My mistake, should have miked it. The thread is .516
diameter so it is 1/4 BSPP with 19 threads per inch.–
In reply to a message from Bruce Cunningham sent Mon 29 Jun 2015:
I ordered a new one from SNG… It arrived and it fit the
hole and threads nicely but leaks from the barrel. Its a
piece of sh…
Some choice words with them tomorrow. Meanwhile we are
trying to unfreeze and fix the old one.
In reply to a message from Bpp sent Thu 16 Jul 2015:
Update: I successfully rebuilt the old one (I think). No drips and
turns freely. It had a small amount of corrosion on the barrel. I
spoke with SNG… and they are sending another one by express
mail. Very good service. I will have a back up! Note the SNG…
one does fit the original 1956 pipe hole, which the other guy’s
ones don’t.–
Bpp
Vancouver. BC, Canada
