Happy Monday to you all!
Charles covered it pretty well, I think.
I have run 15W-50 synthetic for decades now in my VW Beetle and in everything else I own, with the exception of the Model T, AFTER an appropriate break in period. The “T” would have problems with getting the grip it needs from the transmission bands with synthetic, as it runs the same oil in engine and tranny.
The Beetle runs only for a few weeks during the summer when I visit Scandinavia, and it does not get the oil changed every year, and it seems to do just fine. The Beetle engin was designed several yers before the XK engine, and it does not even have an oil filter.
It is not a scientific measurement, but my perception is that every time I have switched to synthetic, my oil consumption has improved.
The E. P. additives (ZDDP) protect the high contact stress sliding surfaces, which first and foremost include the cam to tappet interface and the rings to bore wall. Many years ago, when killing whales was not so not P. C., we used to add some amount of sperm oil to the oil fill at the factory for high performance engines for break in.
The only caveat in running detergent oil in an old engine, as far as I know, would be in its ability to loosen up many years of accumulated sludge and deposits, which could plug up small passages.
In a clean engine it would help keep what forms the sludge and deposits in suspension, which helps to carry it to the filter and lets it drain out with the oil at oil change time.
When I get 672229 running, with a freshly rebuilt engine, I will run a good grade of detergent oil for break in, with added ZDDP, now that Charles told me where to get some, and later I plan to switch to synthetic and perhaps keep adding some ZDDP.
I am not quite sure about the need for the added ZDDP after break in (running in for some of you) based on my experience with the Beetle.
There is some historic data indicating that there were problems with early fatigue on chilled iron cam lobes and tappets when ZDDP was first introduced in engine oils, which caused a massive switch to hardenable iron cams in the U. S. Now, with mostly roller cam followers, the switch has been to nodular iron.
Roar,
----- Original Message ----
To: XK lovers group xk-digest@jag-lovers.org
Sent: Sunday, March 15, 2009 10:47:10 PM
Subject: [xk] oil question
This will be a simple question for most, if not all of you. How do you tell if a
can of oil is detergent, or non-detergent?
As far as being an old, classic engine, I’ll bet my rebuilt, rebored, freshly
honed, and polished 140 engine doesn’t have a surface in it, older than a few
months. What, exactly, are the classic parts that need all the oily zink? The
highly respected VW shop that rebuilt my 1970’s, off road racing engine, said to
use 20-50 synthetic Castrol and the best filter around. After 39 years, I’m sure
there isn’t one original part remaining in it. Would it be considered a
“classic”? The principal is the same for old and new engines. Even jet engines.;
suck, squeeze, burn, pop, blow. What make an engine fall into one catagory or
the other? Thanks in advance.
Aloha, Rob
