I just, ( actually my grandson did), uploaded the 47sec. video on both
YouTube & My Facebook. Here’s the link:
Regards, Otto M.
Regards, Otto M.
Sounds good to me!
Congrats from Scotland.
both
http://www.youtube.com/watch?v=y49wYesiZfERegards, Otto M.
In a message dated 10/14/2009 7:57:19 P.M. Eastern Daylight Time,
externalfeeds@googlemail.com writes:
Sounds good to me!
DJ
Thanks DJ, once I get it to run normally with the front exhaust pipe
fitted it’ll sound even better. Right now the left rear upright is blocking my
fitting that pipe so I have to cut a 2" circle half way up so I can fit the
pipe. That’s why you only see one right now.
Regards, Otto M.
Well done Otto, it sounds good from way down here in OZ.
Regards
Len Brighton
150fhc S824101BW
Wheelers Hill
Victoria Australia 3150> From: Ottman0401@aol.com
Date: Wed, 14 Oct 2009 19:47:47 -0400
Subject: [xk] Re: video
To: xk@jag-lovers.orgI just, ( actually my grandson did), uploaded the 47sec. video on both
Get Hotmail on your iPhone Find out how here
http://windowslive.ninemsn.com.au/article.aspx?id=845706
Otto M;
Best sounding forty-seven seconds I’ve heard in a loooong time!!
Good Going… Now, just sort out the “flat-spot” in the carbs (or one of
them) and you’ll be set…
Give an “Atta-Boy” to your “Cameraman”, he did an excellent job!
Charles #677556.----- Original Message -----
In reply to a message from Len Brighton sent Wed 14 Oct 2009:
Hi Otto,
Great sound. I share your feelings as you imagine.
I have no leaks but I have a metallic noise in the bell
housing. It may be the starter which is remaining engaged. I
need to remove it and see.
Good oil pressure. I also got around 60 which is quite good.
Congrats.–
Regards, Otto M.
Jean-Francois Huguet EType FHC 63 XK120 DHC 53
In a message dated 10/15/2009 1:28:45 A.M. Eastern Daylight Time,
Bishop-13@Texican.net writes:
I thought you’d get a kick out of it Charles, when I get that other pipe
fitted, I’ll run it a little longer with bursts of quick carb. openings to
give it that starting line sound. By the way, the “cameraman” is my 15yr.
old granddaughter, who volunteered, also helped me in relocating the engine
to the test stand. My grandson just pulls the whole thing in & out of the
garage for me. Great kids, love 'em both, lest I forget the little one, just
turned 9 who’s always outside with me keeping me company, she’s my best pal.
Regards, Otto M.
In reply to a message from Ottman0401@aol.com sent Wed 14 Oct 2009:
Sounds great, Grandpa.
As Rick H said ‘‘We need a full report at a First Tuesday’’.
Rich–
Regards, Otto M.
rich neary
perrineville/new jersey, United States
