In reply to a message from bill baethke sent Mon 11 Jul 2005:
Hi Bill
Its probably not much help to you, but on the XK140 gas tank, the
little vent tube disappears down into the tank, and I cant
determine where it goes.
The tank seems to be divided into 3 compartments by two vertical
walls inside the tank. The 2 walls extend from a back wall to a
front wall of the tank, creating 3 compartments side by side.
The vent tube is probably intended to allow air to escape from one
or more of the compartments, while fuel is delivered to the tank,
and the air becomes displaced and needs to escape.
It probably doesnt matter if the little vent tube is missing, as
there is a set of circular holes in the walls inside the tank,
which would let the air move from one compartment to the next
compartment, if the tank is filled up slowly enough. Is there
anything rattling around inside your tank?
As someone previously mentioned, the little vent tube didnt seem to
work too well on the 140 tanks, for some reason.
I have only filled the tank slowly recently, and have noticed no
splashing back or overflowing, so far, so I presume the circular
holes in the walls inside the tank seem to allow enough air
movement among the compartments.
Perhaps someone with an XK150 tank could comment on where the vent
tube is supposed to be found, on that type of tank.
Im intending to shortly clean out and seal up the inside of this
tank, because rust is all flaking off inside there, so the little
vent tube could easily become clogged up with sealant, but I cant
imagine it would matter very much.–
how long your tube is. Also, I saw on a later 150 the vent tube was
Gary Grant S818919DN
Ottawa, Canada
