In reply to a message from Tudor sent Sat 24 Feb 2007:
Hello Barry,
Sorry I can’t help you here but…
I seem to remember that there are two different sorts of rev
counters for XK150s, mechanical ones and electrical ones.
Do you know which sort you have?
Regards
Ken–
Good Day Gentlemen,
On a recent run my rev-counter started to read low and then
stopped working all together.
Does anyone know how the rev-counter generator works? Can I
measure the output to check if it is that or the
indicator.What should the output be?
I took the instrument apart and there are no loose
connections inside and I sprayed contact cleaner on all
connections.
Best regards
Barry Tennant
Try the connector piece on the alternator (that’s what the rev counter
generator is).
There is a bakelite round part that holds the stuff with two small screws;
at the bottom also very small springs, that link the output with the flat
terminals to which the cable from the instrument fit.
More than once, in my E type and S type, the rev counter failed and I
found dirt in that zone, may be due to the tiny gasket was not in shape or
the screws were loose. Cleaned and adjusted, that was all…
Good luck.
Regards
In reply to a message from Tudor sent Tue 27 Feb 2007:
Hi Alberto,
I tried to measure the output of the tacho generator
yesterday to see if that is the problem but there is sooo
muuuch RF noise under the bonnet/hood that the meter just
went haywire!!!
I think I will order some new HT cables tomorrow because
they are copper wired still (I guess they are the original).
Sorry to reopen a very old thread but can someone confirm how free spinning a Tach generator should be. Mine spins but there is considerable resistance.
It doesn’t exactly spin freely, it feels more like a rotary switch with 8 positions. However, it shouldn’t scrape as you rotate it. A common failure mode is for the shaft to work its way into the case, which causes the drive pawl to disengage from the camshaft and the rotor to scrape against the metal back plate. The “E” clip on the shaft should stand proud of the boss, not down inside it.
