I am soliciting repair advice for the body work and sheet metal at
the ‘‘mouth’’ of the engine compartment. This area seems to be a
problem on MANY XK models that I have seen - specifically on the
exterior of the car where the grill meets the car below the bonnet
catch plate and mechanism. I understand that due to design flaws
combined with the thin metal in this area that the car shows
particular stress in cracking paint and metal, particularly at the
corners of the opening.
Has anyone come up with a successful, long lasting solution for
this problem? Do you re-inforce the inside of the sheet metal with
pieces welded in? Do you just live with it?
Any thoughts appreciated. Best, Margaret–
1956 XK140 FHC MC automatic
In reply to a message from jagrestored sent Sat 27 Jan 2007:
Margaret
If you’re referring to that 6’’ or 7’’ wide piece holding the front
of the wings together, then there isn’t a whole lot you can do
about it. Make sure all the fasteners securing the wings are
present and tight. Body shops love to fill in the seam between that
piece and the wing, with filler. It is better left as a seam to
allow flexing, without cracking the filler. It would probably even
be a good idea to loosen or remove it prior to painting so the
paint didn’t crack along the seam. Also, avoid hitting deep
potholes or curbs.
Joel–
ex jag, '66 E-type S1 4.2, '56 XK140dhc
Denison, TX, United States
Margaret
FWIIW on both the FHC and the OTs this piece was rotten and had to be
replaced…superbly fitting replacements were procured from Schelin in CT.
Best
Klaus-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
jagrestored
Sent: Saturday, January 27, 2007 3:07 PM
To: xk@jag-lovers.org
Subject: [xk] Sheet metal problems on Jaguar body
Hello List,
Margaret
CT.
Best
Klaus
Check out the new AOL. Most comprehensive set of free safety and
security tools, free access to millions of high-quality videos from
across the web, free AOL Mail and more.
Dear Margaret
The problem you describe with the tie piece between the front
fenders should not be a problem except possibly in some harsh
conditions, assuming the piece was worth fixing in the first place.
In the event your bodyman knew to straighten everything else on the
front end first another possibility is that an attempt was made to
weld the area without completly removing all the old lead,big
mistake to be lazy in this area.The majority of the XK’S used a
fair amount of lead in the seams up front and one would hope you
found someone to duplicate that verses that stuff you mix with
hardner,it just dosen’t like to be spread on that thick.Sure did
like Toby’s horn repair–
VAS
