In an effort to learn something about sheet metal working, I have
been re-reading a few books on sheet metal and bodywork. During the
past few weeks I have been working on trying to make a spat to fit
my 140.
Probably have about 25 hours of effort into it so far, including
some time head scratching and wondering what to do next, as well as
some time making up some wooden forms. This spat is easily
identifiable as a non-authentic version, because, among other
reasons, the inwardly facing flange around the edge is not made
from a separate piece. And after it gets painted, perhaps the fit
will not seem to appear so good. However, for a first attempt at
making a spat, this one is coming out much better than the dented,
wrinkled piece of sheet metal slathered with bondo which I
partially expected to end up with. From a distance it doesnt look
to bad at all, or maybe my standards are sort of low
Anyhow, the edge of the wheel opening in the wing has been all re-
formed and smoothed out to accept a spat. A po had flattened out
the edge of the opening, probably when the original spats were
discarded back in the mid 1960s. I have previously contacted the
second owner of the car, and he doesnt have any XK140 spats, and
doesnt recall what happened to the original set
I had to make a mounting peg to attach the front of the spat to the
wing, and the rear original peg is still there. I used a repro
latch mechanism and chrome lid
Anyhow, this spat is now pretty much all completed, as far as
metalworking goes, with no bondo used (yet) ! I will probably use a
skim of bondo in a few places to smooth out some file marks before
painting, and then hopefully this spat may be good enough to
actually use on the car. The spat fits nicely in the wing opening
and has ended up being slightly curved so its surface lines up
pretty good with the wing surface. The gap betwen the spat and the
wing actually doesnt look too bad, as the edge of the spat is
leaded and can be filed to have almost any shape
Soon I will be starting to make the right hand spat, and will try a
new method, making the inwardly facing flange out of a separate
piece, so that one may possibly end up being somewhat more
realistic in appearance. Maybe not, though, as the inward facing
flange seems to be important in creating and maintaing the actual
shape of the whole spat
On this first spat, the inwardly facing flange has been made by
making pie cuts all along the edge, folding the edge over 180
degrees on itself over a wooden form, then bending back inward 90
degrees against another form, then welding up and smoothing out all
the little pie cuts. By luck, the steps of drawing the pie cut
edges together and welding them seems to have created a nice
curvature in the outer surface of the spat which allows it to
almost match the curvature of the wing surface.
Anyhow here are some pictures of how this first spat looks at this
stage.
http://www.jag-lovers.org/snaps/snap_view.php3?id=1201455112--
Gary Grant S818919DN
Ottawa, Canada
âPosted using Jag-lovers JagFORUM [forums.jag-lovers.org]â
