Gentlemen,
I have been following this thread and like to try and clarify the discussion
so far. Some observations according to the parts catalogue for the 120.
Item T49 part number C3829 is described as a ‘packing piece’ used only on
ENV rear axles but not all ENV rear axles. Only rear axle part numbers
C3452, C3821, C4461 or C4462 had them. Rob’s car 679187 would have been
fitted with an ENV rear axle in the part number range C5150 through C5154
and therefore would not have required them to be fitted. At the present
point in time, I understand we do not know what form this packing piece
takes, as this elusive animal has not been sighted. It could be a tapered
packer or in fact, it could be nothing more than a large shim not designed
to change any angles.
As far as the 140 goes, according to the parts catalogue, all 140’s had a
fibre taper wedge P/N C3186 fitted and all cars had a 4HA rear axle fitted
although four different ratios were available.
Is this understanding correct? If this is correct what changed between the
last of the 120’s and the 140 to require the wedge?
Ken Godbaz, Auckland NZ
672431 & S814013-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
Ed Nantes
Sent: Friday, 26 September 2014 12:55 p.m.
To: xk@jag-lovers.org
Subject: RE: [xk] taper wedge, axle to spring
In reply to a message from Rob Reilly sent Thu 25 Sep 2014:
Rob
I would think the ’ average driving conditions [ height] is to
allow for suspension movement either side of ’ centre’
Universals have an optimum range of movement. The longer the
shaft, the less angle of movement.
The half shafts of an independent Jag rear end probably have a
bigger range of movement than the tail shaft of a MKVII
It may have been this factor that caused Jaguar to make gear
boxes with shorter rear extensions for SS100s and XK 140s.
I think the wedges were to lift the tail shaft up to clear it
over the middle cross member… The MK V and VII had similar
chassis but longer so not a problem and no wedges.
If it was too keep the joints parallel it would’t work at the
time when under greatest load… when accelerating, and the
springs wind up.
Do we know definitely whether only ENV diffs had the wedges?
If so it may be to do with the dimensions and placement of the
line of the pinion
The ENV being front loading the Salisbury rear loading, quite
possibly they differ.
But it’s nothing to do with XKs. I can only see one purpose
for these on an XK rear axle, which is to set the
differential pinion shaft where it is parallel to the
gearbox mainshaft most of the time under average driving
conditions. It seems odd that the factory couldn’t get this
Ed Nantes SS
Melbourne, Australia
