G’day Harv (and others).
Whilst restoring that part of my XK140 OTS - thus the source of all the
photographs used for the line-drawings in XK140 EXPLORED - as with
everything else, I really went very much into the detail and understanding
as best I could - so thus the greater degree of detail/captioning within the
XK140 EXPLORED plates.
But a few interesting observations.
My leaf-springs, still with 3/4 intact original Gaiters - were in perfect
condition still with no apparent sag, so all I did was disassemble them,
lubricate with a molybdenum-base grease, rebush them with accurate
metallastic bushes (and there are correct and not so correct repos
available) and I also had machined up slightly modified centre-bolts, then
reassembled springs with these ‘upgraded-bolts’.
The reason of course was the subject WEDGES.
My leaf springs had stamped on the lower-surface of the smallest leaf (I
think without checking notes/photos) a makers logo, Jaguar Part Number and
also a date, and both my leaves were 1953/4 dated so presumably old XK120
stock finally fitted to my 1955 XK140. But late XK120SE and XK140 use the
same rear-springs so that is fine.
But before I disassembled springs from rear-axle mounting brackets, after
thorough cleaning and inspection I had noticed that on one side I could see
the depressed crown of the spring centre-bolt only 1/2 engaged within the
thickness of the locating hole in the mounting-bracket. But on other side,
I could see daylight, with the crown of the centre-bolt offset from hole
about an 1/4". So after disassembly of the excruciatingly tight “U” bolts
secured by NUTS and LOCK NUTS, I was able to see that this one misaligned
Centre-bolt had either been not assembled properly located into the hole
(likely) or had ‘jumped’ out of hole during its low-mileage on-road use
(unlikely). So looking for the reason, I decided that adding these wedges
was an afterthought introduced maybe from XK120 initial use of Salisbury
Rear Axle, thus need for these wedges as it was too late to better slightly
redesign rear-axle bracket, or maybe an in-service design upgrade for later
XK120s recognising need for better alignment of prop-shaft to input pinion,
or as has been suggested, an improvement/modification introduced for XK140
rather than introduce another Rear-Axle Assembly part number and control for
production/support/spares reasons.
Thus I am interested in current comments from XK120 owners about these
wedges, but I am not hearing to much first-hand-awareness of them, so as
then, I still tend to think the wedges were introduced for XK140.
But by adding wedges, whilst still using unchanged spring centre-bolts,
means difficulty in reaching/aligning centre-bolt head with hole in
rear-axle mounting bracket, and once located, minimal engagement.
Thus my example - one side with minimal but correctly aligned engagement,
the other misaligned and not engaged, but bolted up tight causing head of
centre-bolt to punch an offset depression in rear-axle bracket.
So I repaired depression in bracket, but also decided to add height to the
head of the centre-bolts, such that on assembly with new WEDGES fitted, the
centre-bolts fully engaged to be flush at top surface of bracket, so no dirt
trap/obstruction through the bracket hole.
Now you don’t just go and buy new High-Tensile Steel XK140 Rear-Spring
Centre-Bolts with a modified /increased head height from your local
specialty-fastener shop, nor indeed the usual spare-parts-outlets.
So what I did was I looked for and found some High-Tensile Cap Setscrews
(those with a round head but with a female-hexagon-drive, that compared to
my original Centre-Bolts had an over-diameter and over-height head, the same
bolt shank length, and an over-length BSF thread. I machined the head down
to correct diameter, and down to my design increased-from-original head
height, and cut excessive BSF thread-length back to original bolt length.
End result was a HIGH TENSILE BSF Centre-bolt with a taller-head.
Should see me out, and my daughters inherited ownership, so all I have to do
is not tell any future Concours Judges about this non-authentic
modification, whilst being happy that I should never have a
rear-axle-alignment issue if I go bouncing over pot-hole roads at speed!
But worth having a close look at how yours is, and how well it all
re-assembles.
Roger Payne - XK140MC OTS; E-Type 4.2 S.1 OTS; DSV8.
Canberra.-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
Harv XK 140
Sent: Friday, 3 October 2014 7:30 AM
To: xk@jag-lovers.org
Subject: RE: [xk] taper wedge, axle to spring
In reply to a message from Ken Godbaz sent Sat 27 Sep 2014:
I just want to thank you fellows for bringing this wedge
topic up. I have since found both wedges and now I will
have to redo the work that was done by the past owner.
However, it is a lot better to find out about this now, as
I don’t have the body on the chassis yet.
Again … thank you; thank you
XK140 Explored’’ page 183, illustration 3-e2 and this shows the wedge
C3186
Harv XK 140
