Finally got back to the Xk120, had to get away from it for a while
to calm down, plus a trip to Chicago area to visit daughter and son-
in-law. Removed the head and measured the composite gasket,
measured from .075 to.080 at various spots, compared to .017 for
the stock gasket. Then I put on an old 120 head that had been
surfaced at least once, with the composite gasket and had no
trouble hooking up the timing chains. Called the supplier to find
out if they carry the composite in different thicknesses only to
find out they have but one size(thickness). Not sure of my next
step, will probably rebuild the 120 head.
Can any math experts calculate how much of a compression difference
that thick of a gasket would make? Not positive of the compressed
thickness, but I would guess at least .050, I know it was over .045.
As a side note, I’m rebuilding a 1275cc for my 64 Austin
Countryman, and I have seen Cometec(sp?) head gaskets on ebay, they
start at twenty-some thousands, and go up to seventy something.
Bill Seibold–
Bill 120 OTS
New Philadelphia, United States
Bill,
Gosh, I feel rusty, but I did try to go through the numbers.
Assuming that your bore and stroke are stock, and that your compression ratio starts out at 8:1, and further assuming that your compressed gasket was 0.017" and is now 0.050", your new compression ratio will be 7.63:1
Somebody better check the numbers and keep me honest!
Roar— On Tue, 7/20/10, BS wseibold@roadrunner.com wrote:
Subject: [xk] Update; shrunken timing chains
To: xk@jag-lovers.org
Date: Tuesday, July 20, 2010, 1:53 PM
and son-
.017 for
been
no
to find
only to
next
difference
compressed
over .045.
ebay, they
something.
Bill Seibold
Bill 120 OTS
